I was given a 1964 Sportwin 9.5 outboard model 9422RA.
The p.o. said he was running it on the lake and all of a sudden it quit. The cylinder head is discolored from overheating.
I pulled the lower unit and tried running water up the intake but nothing came out anywhere. I pulled the thermostat and tried pouring water down through the thermostat tube and water barely trickled out from somewhere, but not the intake tube.
It looks like the impeller is new. I need to check back and find out if my friend changed the impeller after the motor quit on him. I suspect he did and the previous impeller had thrown chunks up the intake.
So I'm pretty sure I have something clogged in there somewhere. I can run a wire up the intake tube all the way to the powerhead, but can't really get anywhere down the thermostat tube because it takes a right angle at the bottom.
The thermostat was pretty dirty but after I soaked it a little in vinegar it opened up at 160 degrees. From what I understand that's higher than it should be but I don't think thats the cause of the overheating.
I can turn the flywheel okay. The cylinders don't seem to be frozen up. But I have not attempted to start the motor.
I do have a Clymer Evinrude/Johnson shop manual for 2-40 hp '73 to '87. But none of the pictures seem to be for my particular model.
One more thing. Since this motor was a "gift" and I really don't have a particular use for it at the moment, I have two goals that are pretty much even - resurrecting an old motor from a trip to the junkyard and learning more about outboard maintenance. I also have a 1976 6hp Johnson OB for my sailboat.
Armed with this information, what is my next step? I'm hoping to avoid pulling the powerhead if there's any other way to find the clog. My big concerns are that water doesn't come out where it should from the thermostat and that water doesn't go anywhere from the intake.
