Need help removing manifold. I've removed the carb, riser, etc. Removed the bracket holding the drive lube monitor. The only bolts I see left are the 2 that go through the center of the manifold. One is a bolt that goes through the manifold, into the head, near the front of the motor. The other is a stud with a nut near the rear of the motor. I've removed those and I can't find any other fasteners yet the manifold isn't moving. Before I smack it too hard with the hammer, are there any other fasteners? The service manual simply says "remove fasteners, remove manifold".
Thanks,
Tom
Thanks,
Tom
