1978 evinrude problem
alejandro10
hi,i have a evinrude 1978 115hp. i need a new starter the model number is 115893c. 10 tooth.do i have to used this model or can i replaced it with a different model?:confused:
rsimmons42
Re: 1978 evinrude problem
you need to use the correct starter, but there are different places that you can get it. I would recommend checking at your local Napa auto parts. They offer a great line of marine parts. Here is the page from there catalog of the starters that would work for your motor. The ones starting with the #18 are the ones that you can order dirrectly from Napa auto parts. Here is there link
http://www.marineengine.com/newparts/part_search.php
JB
Excuse me for interrupting, but you may be about to waste some bux.
Why do you need a new starter? What is wrong with it? 60% of starters that are replaced didn't need replacing. They simply needed the wiring cleaned up.
A starter that really is bad can be rebuilt by an automotive starter shop for a small fraction of the cost of a new starter, and it will be the correct starter for that engine.
