1978 70hp johnson short
swingline327
just fired up the old johnson, got it running ok but it doesn't shut off with the key. it also shocks the crap outta me like i was holding on to a coil wire if i touch the boat and block.
i was hoping someone has had a similar problem or a link to wiring diagrams.
anything that might help will be appreciated.
Joe Reeves
Re: 1978 70hp johnson short
You've got an open ground somewhere. The kill circuit is:
Black wire from powerhead to powerpack, black/yellow wire to raised "M" terminal of ignition switch, black wire from other regular "M" terminal of ignition switch to ground.
swingline327
there is some corrosion on the grounds but all seem to test fine, is there one that might be the most likely
maybe the coil grounds?
Joe Reeves
Did you remove and clean those connections, then retighten?
Does your engine now shut off with the key?
swingline327
won't get around to that until tomorrow, but i'll clean all the corrosion, i think
it got wet with saltwater at the end of last season
swingline327
do you think a plug wire arcing to the block could cause me to get shocked, or is that related to a bad ground
