How do I know which Volvo Eng. I have?
tmbarnes77
I recently purchased a 1984 Bayliner Ciera BL2, the title says the boat is 20' 8" long. The engine is a four cylinder with a 270 outdrive. I cant find anywhere on the engine what model it is so i can order parts or get info for tuning. Can someone please help me with this if possible?
tmbarnes77
Re: How do I know which Volvo Eng. I have?
All i need to know is if it is a aq125a, aq131a, aq145a...or did bayliner put a variety of engines in those boats that year and nobody knows. I cant find a thing online and i have searched everywhere.:confused:
Don S
Call Bayliner toll free at 877-861-6494 and have your Hull ID number handy. They can tell you what engine came with the boat originally.
There is also a brass embossed tag on the port side of the engines either near the fuel pump or around where the starter mounts.
tmbarnes77
That phone number is no longer in existance i called it and no dice. Try it you will see. and unfortunatly my engine has no brass plate data.
Ayuh,... Post some Pictures....
tmbarnes77
Im trying to post pics but they are too big for this forum to handle they are 101kb and the max allowed is 97kb. REDICULOUS!!!!
Ayuh,... 480x640 works real good here...
180shabah
...the max allowed is 97kb. REDICULOUS!!!!
There are currently 2,042,885 posts on the site, many with pictures. Without the limit do you have any idea how much storage space would be required?
If you simply must post a large picture, use a hosting site like snapfish, webshots etc.
