I need help regarding af strange problem regarding my mercury engine, there are no problems i starting and sailing but after 10-15 sec in full speed the alarm sounds !! it keeps doing that until i pull the throttle a little bit back - stil sailing at max speed - then the alarm stops
and everything is ok - then i give max throttle again and the alarm sounds again ?? there are lots of water coming out of the engine and the exhaust i ok. Do the engine have at alarm if the rpm gets to high ? or could it be the heat sensor ?
