oil leak lower unit
sctom
after running short time out of water oil leaks a bit from around prop, no evidence of water, smell of burnt oil/gas is this normal?
Barnacle_Bill
Re: oil leak lower unit
If your motor is running ruch a little might be normal. Check your lower unit for water intrusion.
Gary H NC
best way to check for water intrusion?
Drain the gear lube out of the lower.If its had water intrusion you will see it in the oil.
I bet what you are seeing around the prop is unburnt fuel-oil mixture.
Very normal when running on the muffs especially if the motor has not been run much in a while..
sctom
thanks, appears what is happening, not ran since last year
Gary H NC
If it was gear lube leaking it would have that strong smell to it and be really thick..
I bet once you get it in the water and run it good it will be fine.
It never hurts to check the gear lube though..
I change mine 2 times a year just to be safe..;)
