Help Pick 4 hp motor
Nawanda
I've used a MinnKota electric for years, with 50 ft/lbs thrust.
I think a 4pm 4 stroke will do nicely to replace.
Can anybody give me a rough estimate or power ratio in comparing 50 ft/lbs thrust on a MinnKota compared to a 4 HP? How much faster can I go.
I'm looking at Mercury, Yamaha, Nissan and even used Johnsons (2 cyl).
Please share your knowledge.
Re: Help Pick 4 hp motor
Here is some reading material,
The power absorbed by a hull is its resistance (wave drag, skin friction, etc.) multiplied by the speed at which it is travelling.
The actual power produced by the engine is substantially larger, as much of the engine power is lost to inefficiencies at various points in the system. For example, a gearbox might take 3% off the engine's brake horsepower, and a typical propeller would convert 50-60% of the horsepower that reaches it into useable thrust. (Really good, well-matched props can sometimes be 70%+ efficient.)
When you look at a trolling motor rated for something like "55 lb thrust", the figure given is often the maximum thrust that motor will give. Let's say for the sake of argument that you'll be going at 2 knots, or 1 m/s with the trolling motor at full power. If you're getting the full 55 lbf of thrust at this speed, then your hull has 55 lbf total resistance at this speed. 55 lbf = 0.245 kN, so (0.245 kN)*(1 m/s) = 0.245 kNm/s = 0.245 kW. That's about 1/3 hp.
Now, once again for the sake of argument (these figures might not be representative of your actual setup) let's say your propeller efficiency on that trolling motor is 50%. Then it's actually producing 0.49 kW or 2/3 hp. Electric motors aren't perfect, let's say our example motor is 80% efficient at full power, so we're up to 0.62 kW of electric power that's actually being sent into the thing. At 24 volts that's about 26 amps; at 12 volts, more like 52 amps.
To compare against a gasoline engine is a little harder. An outboard's SHP rating is usually at full power (very near WOT) and usually measured at the propshaft. To get the same 55 lbf of thrust as above, again with a 50% propeller efficiency, we get the exact same 0.49 kW or 2/3 hp. Shaft power has the exact same meaning regardless of what is turning the shaft.
The question becomes, then, what gas engine will produce 2/3 hp at the prop shaft. You'd probably find that a 2 hp outboard at about one-half to two-thirds throttle would be roughly equivalent.
Now, all of what I've just said rests on a big assumption- that we actually know what thrust the trolling motor is making at a given speed. Short of putting strain gauges on its mounting bracket, we generally don't- and can't- know this value accurately.
But the key message in all that math I just posted is this: You cannot make a direct comparison between thrust (force) and power, unless you also know the speed of the vessel when it is absorbing that thrust or that power.
__________________
ondarvr
Lots of info there.
The short anwser is almost any gas motor will put out more thrust than even the biggest electric motor.
Do yourself a favor and get the used two cylinder J/E, its a far better motor than what's produced now in that HP range.
kenmyfam
Used 2 stroke Johnnyrude. Great little motors.....wish I had one.
ezmobee
I have an 89 Evinrude 4HP Deluxe. The Deluxe means it has reverse. It is light and has great power for a 4. I think you'd be hard pressed to find a better value. I had a ~1980 Evinrude 4 before that was a stripped down model with just neutral and forward. It was SUPER light and we ran the hell out of that thing and did not take care of it at all. We sold it running last year.
