Need serial number info.....please!
carpman
I am looking at a motor and all I have is the serial# and markings on the side of the cover and shaft. It's a Mercury and is marked 9.8 HP on the cover and motor and is electric start w/ controls. The serial is A901281. Would like to know the year/model/ and 2 or 4 stroke. Thanks in advance!
Dunaruna
Re: Need serial number info.....please!
That is not a good number, it does not show on any lists.
0A90xxxx would fit into the sequence in the mid 80's.
AMD Rules
Serial number is okay, as it shows up in Merc EPC database.
Serial No.: 0A901281
Model No.: 1010525
Part List No.: 90-13716
9.8hp 2cyl, 2-stroke
It has the squared off one piece molded cowling, so I'd agree its probably mid-80's. I'm thinking late 1985 era.
Does it happen to have a brown colored band?
carpman
Yes, it has the brown band......so late 80's then. And are you 100% on the two stroke? The only reason I am asking is it has full controls and came off of a pontoon..for some reason that just has me thinking 4 stroke. You are probably right though since that came from the database!
Thanks for the information!
AMD Rules
Definitely 2-stroke
Definitely 1984/5 model.
Good luck.
