I have a 2001 9.9 Honda 4 stroke and it has remote controls with key start. It starts after it has been cranked over about 20 times. After it starts it will run fine for about 3-5 minutes then slowly die. It will start again after a few minutes and then will again die after running for about a minute. Primer bulb does not get very hard too when I pump it a few times at start up. It cranks a bunch of times if I immediately try to start it after it dies with no luck. When I tilt the motor out of the water it will start right away at that angle. Of course I kill the motor right away to not damage it. I pulled the line off of the carb and pumped the primer bulb and it squirted strong. Is this normal right after the fuel pump? Does the pump restrict the pressure? Any help or suggestions? I was trying to take the family out today and now this happens
. Thanks for any help! Anthony
