new guy here
i bought a 1974 alantic 17 footer with a 1976 Evinrude motor
Its my first boat and i was wondering what i need to do as far as getting the boat in the water
it was winterized last season so it has fresh oil in
lookes like the carbs my be leaking some fuel around it
boat runs but owner stated that its hard to start after it warms up
so any help you guys can give me would be great
and how can i tell if its a 2 or 4 stroke motor
sorry but i am new lol:)
bankerjohn
Re: new guy here
Since you didn't specify the size of your motor, you need to start out by giving us the model # from the plate on the transom bracket ... something like "E70ES74" (1974 Evinrude 70hp) ... or whatever.
Re: new guy here
sorry its a 115 forgot to add that
bankerjohn
Re: new guy here
Your model number should be "115493B" or something very close to that. It's definitely a 2-stroke motor.
Hard starting when warm and leaking gas sounds like you need to have the carbs rebuilt!
Are you planning on working on the motor yourself? If so, you need to buy an OEM service manual before you start tearing things apart!
Check spark, check compression, change lube in gearcase, install water pump kit, etc., etc., etc.
Re: new guy here
the lube is changed new water pump on it compression is good new coil packs on it how much would some one charge for rebuilding the carbs just so i no a price range when i take it in
jonesg
Re: new guy here
Get the manual first.
www.outboardbooks.com
being new to you and you being new to outboards...theres a lot to learn before blowing the engine up, they last for yrs but need a certain amount of attention. Its not rocket science and few of us here are techs.
A 13 yr old can rebuild carbs ( in fact some 13 yr olds here do)
a shop will probably charge you $100 per carb.
watch how simple it is to rebuild your carbs.
http://www.youtube.com/watch?v=o5cxBMDezuU
I got my first johnson 150 last yr, knowing next to nothing I hired a mechanic from craigslist and we went through it top to bottom.
I don't believe anything sellers say. !
Re: new guy here
sounds like something i would like to try any why someone can show me what parts i am going to need
put the links up so i dont order the wrong things and the right manual for my motor 1976 Evinrude 115 cause i dont have a clue were to start
local shop wants 450 dollars to do it
jonesg
Re: new guy here
You aren't giving us enough useable information to help you out.
We need the model number. Its on the mounting bracket , there should be a plate, or look on the engine block for a silver disc with numbers.
You can't order certain parts until you know the exact model, its hard enough even with the right model number for me.:eek:
You can probably go ahead and get the carb kits right here on iBoats.
see if your model number is listed here, if not ...it might not be a 1976.
http://www.outboardbooks.com/index.cfm?fuseaction=items.main&boat=JM Outboard Motors&orderby=year
Should be one the models listed.
Order the factory service manual, not the owner manual, its the best $42 you will spend.
I have no luck searching for parts on iBoats, but you can call them, they have very good customer service 1-800-743-1123
It "might" be this, someone needs to double check me on this.
http://www.iboats.com/mall/partfind...gd_poid=109334&gd_row=61&**********=913324678
The problem is, how do you know what year your engine is if you don't have the model number?
bankerjohn
Re: new guy here
Or you can search eBay for "1976 Evinrude 115" ... there are several factory service manuals currently listed for less $$$ ... as well as some parts manuals.
Re: new guy here
model number is 115493-B
