I have a '58 evinrude 10hp that I am trying to wake up. I bought this motor a couple of years ago, so it has been sitting. Anyway, I just can't get spark anymore. Below is what I have done so far and some results:
1. Have gone through everything as per "top secret" thread on waking a sitting outboard. The outboard has always turned freely.
2. Bought new coils and tune up kit. Installed to specs. Got spark. I sprayed a little gas/oil mixture into the carb to get things started. Put on the choke. And away she went...for 15-20 seconds. When I released the choke, she stalled. Put it back on choke, would not start. Sprayed gas/oil into carb, would not start. Tested spark, no more spark in either cylinder.
3. Took off flywheel and cleaned points, checked coils, etc. Put flywheel back on, and no spark.
4. Took off flywheel, took amature plate off shaft to check plug wires. Wires were fine, no cracks, clear path based on multimeter. Put it all together. No spark.
So what could it be?! Coils are around 7000 ohms. Coils, points, and condensers are all new. Started fine the first time, but lost spark. Am I missing something?
