Run trolling motor on dual purpose battery?
mike64
I just bought a used Minn-Kota 50lb thrust trolling motor. I'm planning to do a little trolling with it, not hours of trolling, and I wanted to have a backup in case my OB dies on me.
I go out on inland lakes, the largest one 1280 acres. I have a dual-purpose battery that I always fully charge before I go out.
Can I get away with running the troller off the dual-purpose battery, or do I really need to get a second battery? If I run the trolling motor for a 1/2 hour say, am I asking for trouble when I try to start the ob again?
JB
Re: Run trolling motor on dual purpose battery?
I have never used dual batteries. Always used one, and for the last 20 years that one has been the biggest dual purpose battery Wal Mart carried: Marine Maxx.
Never did any real trolling with the electric, but worked along shorelines, around weedbeds and rock bars for hours at a time.
I think you can get by with one big dual purpose battery like the Marine Maxx.
mike64
Thanks, JB. i took a closer look at my battery (that came with the boat)-- it says right on it "Designed for both marine starting and trolling motor deep cycle" so I guess I'm ok with what I have.
It's a Stowaway 27DP-6. 730 cranking amps, 160 reserve capacity. I know that's not the best battery out there, but it holds a charge well-- never takes long to recharge it, even when I forgot to give it a charge for a couple months last winter. I'll test it out with the troller tomorrow.
nimmor
For just a 1/2 hour of trolling unless your battery is on it's last leg you shouldn't have any trouble. I would say you probaly could go with even 4-5 hours of trolling with no problem, depending on how much the motor draws juice. Some of the newer ones don't draw that much.
mike64
So I tried out the trolling motor today. The battery handled the drain from the motor fine, not that I ran the motor that long. The motor, however, didn't do so well. It was a fairly windy day, and when I tried trolling in a little bay the wind blew me right into the weeds. So I took the boat out into open water on the lake and tried again, but with the wind and the choppy water the motor wasn't doing much. So I gave up and fired up the ob. If it was a perfectly calm day the troller might get me back to the launch if my ob dies, but any wind at all and forget about it.
This is a transom mount troller, and I probably should have a bow mount for my size boat (16' v-hull ~1000 lbs.). But the way my bow is designed there's really no place for a bow mount. And I like to stand and fish from the back of the boat so I figured I could work the tiller pretty easy while I'm fishing. But the wind just blows the front end around like it's a big sail. So there might be a 50 lb. thrust Minn-Kota going back on craigslist real soon...:rolleyes:
rndn
Are you really going to be able to enjoy fishing with the trolling motor wondering if you still have enough juice to start your outboard? Buy a second deep cycle so you can enjoy fishing.
