Re: OMC Control Help
When you reconnect the two sections of the remote, the control arm must be in neutral and locked in place with the neutral lock slide on the handle engaged in the locking slot/notch.
See factory service manual for assembly:
"Control handle should not be able to move without releasing the neutral lock slide" (on the arm).
"If the neutral lock slide does not engage the notch in index plate when neutral switch is centered on the neutral cam,, it will be necessary to reposition either the control handle or the index plate."
