warnockdonald
- May 30, 2009
- 6
I ve got a 1990 tracker 115 that i'm having problems with.The motor was gave to me by my uncle about a year ago.It was on another boat and i put it on my 1987 18 foot tracker pontoon boat.I tore the end off of a plug wire putting the cover on last year, i repaired it and it ran fine when i took it out.It sat up about a year and i got it out and went fishing a couple of weeks ago and it's running like crap.The first thing i checked was firing.I replaced that wire and it's firing on all cylinders.Then i went to the carbs.The bowl gaskets were rotten and i cleaned the carbs and replaced the gaskets, the carbs look like new inside even before i cleaned them.I ran it on a a set of muffs and it seemed to be running fine.Went fishing last night and it ran good for the first 100 yards and then starting bogging again.I took the fuel pump apart today and it looks like a brand new one, i couldn't find any problems.I'm sure it's a fuel problem because i can choke it and it'll try to open up, that's why i thought fuel pump.The ball is staying firm.I'm going to do compression check tomorrow, but i would like any suggestions to help me figure this problem out.
