frustratedboater
- Jul 10, 2007
- 484
Greetings all,
As from other posts I put up, I had experienced very rough idle in my Mastercraft, 87' Chevy 350, and had a pop/backfire sound inside the intake manifold while having a very rough idle. I double checked the firing order, rebuilt the holley carb completely (needed it anyway), and checked my point gap setting, so were solid all around.
I took a compression test in all cyls' and here are the numbers:
Cyl-1, 150
Cyl-3, 165
Cyl-5, 165
Cyl-7, 160
Cyl-2, 160
Cyl-4, 175
Cyl-6, 140
Cyl-8, 148
As you can see cyl's 4 & 6 have something going on. When I screwed in the tester in cyl #4, and cranked it over, it had much different sound than the others. It had a double cranking sound while cranking over and posted a much higher PSI.
The engine oils is amber clear and that motor is cooled by seawater pump through the hull. Without tearing it down yet, can anyone make some predictions as to what I'm going to find? Intake gasket? Head gasket? Just my imagination???:redface:
Frustratedboater-
Cyl-1, 150
Cyl-3, 165
Cyl-5, 165
Cyl-7, 160
Cyl-2, 160
Cyl-4, 175
Cyl-6, 140
Cyl-8, 148
Frustratedboater-
