1984 johnson 90Hp
I have a "84" 90Hp Johnson that fouls one of the bottom plugs and will not clean out.
VRO is unhooked, gas is mixed 50:1 (well mixed)
carbs have been gone thru
Coil on the cyl. has been replaced
Plugs and wires replaced (Twice)
Comp. is good 125,125,125,130
Still it fouls that one cyl. and runs as a 3 cyl, All the time.
I'm lost !
Any ideas???
tashasdaddy
Re: 1984 johnson 90Hp
are you using Champion QL77JC4 or QL82C plugs, gapped at .030?
kenmyfam
Correct plugs vital. Carbs been rebuilt recently ???
crxess
Check the carb on that cylinder for a loose/damaged/missing orifice plug on that side of the carb. Might be introducing to much fuel.
If possible, swap carb positions and see if the fouling moves to the other cylinder on that side of the carb.
Carb could have an internal crack on orifice passage drawing excess fuel into the cylinder.
chubcobear
Is it possible the #4 cylinder plug wire is grounding to the hood latch bolt on the port rear side? That happened to me (J90TLCUR). It left the plug clear and wet, not firing.
