I have a 2006 Merc 90 O/B. It's been great until this spring. Now the power trim only lifts the motor 1/2 way up. The trim motor runs fine and doesn't appear to bog down it's just that it won't lift the motor any further than 1/2 way.
I manually lifted the motor, drained the fluid which appeared ok, (not cloudy) and refilled. I then repeatedly lifted the motor manually and lowered under power several times to try to get any air out of the cylinder. When trimming up the ram lifts the motor only 1/2 way then slows and stops but the pump still runs and sounds fine. When I lift it further by hand and release it, it drifts back to the 1/2 way point where the ram will hold it with no further drifting down.. Any additional troubleshooting suggestions would be greatly appreciated. And, yup, just out of warranty!!
