Had my 67 seahorse into the shop this spring after some tips on here about needing a new clutch dog and forward gear. Had a local marina do the work and they said they could repair the linkages for $100 and it would be good to go (opposed to $500 for new). I have done a lot of other work on this motor this spring including new points coils etc, new head and gasket as the old one was shot, and new throttle and shift cables. It worked great for about 8 hours and now is slipping out of gear again whenever under a load in forward. I have disconnected the cables and shifted it by hand and it still happens. Is this definetly the clutch dog again or could it be something else?
What are the symptoms of a sheered flywheel key? We had to replace that as well and then torqued it back to 105. I want to make sure it is not just a sheered key before tearing apart the lower unit for to work on the dog.
Thanks for any help.
