krisnowicki
- Jul 11, 2007
- 1,172
I got the aq125b engine/ 270 outdrive trophy today.
I have a couple questions.
1. I want to do a complete tune up, is there a manual for this set up?
2. from what i understand the water pump is on the engine only there is no pump in the drive?
3. The gear ratio for the 270 is determined by the lower unit only?
4. What are the appropriate spark plugs, points etc tune up part numbers?
5. Where is a good place to get a carb rebuild kit?
6. The 270 does not use drive oil but regular 30 w oil is this correct?
Thanks for your help
