1984 Force 85 HP
it has some difficulty firing up and starting, but usually does with some TLC. I can handle this. Initial running is smoth, no real problems.
However, problem in question is when trying to start motor a 2nd, 3rd, ..time (after stopping boat purposefully), boat is almost impossible to restart. After purchase, seller (a family member) stated that you had to prime the %$#$# out of the bulb when this happens....almost to the point you "think" you are flooding motor... This has worked on some occasions, but still a problem. Boat/ motor well maintained.
carb kit 2002
water pump 2002
Power pack / stator 2007
Suggestions ???
carb kit 2002
water pump 2002
Suggestions ???
