The DT8 serial # is 0801   107443  and is blue in color.  I was thinking an 1981 model?  I inherited a fairly unused DT8 (30hrs.) from my father in law about a year ago,  I am having a problem with the Carb,  For some reason it'll crank on the 2nd pull as always then start stumbeling about 30 seconds afterward and start spitting fuel from the top vent in the Carb... I cleaned it well and put it back together and it ran great, I then added seafoam as directed in hopes of preventing the issue from happening again, recently the problem has returned and now the cleaning wont help, we rigged the float thinking that it was the issue and it runs fine until you are underway for probably 2 or three minutes then it boggs down and shuts off, I noticed the pump bulb on the fuel hose doesn't stay tight all of the time(doesnt have much preassure)  the problem is sometimes fixed when I pump that bulb up but sometimes it doesnt work and the motor stalls.  I was thinking I need a carb rebuild...  Any clues to what it could be?
Thanks,
Cwil
			Thanks,
Cwil
