drain holes
gen
Just purchased a 1988 champion bass boat (1rst one) dont know which hole to plug need some help
QC
Re: drain holes
Moved this over to Boat Topics to get you some more help. Are you talking about the bilge drain? Lowest hole on the transom.
Oh, and Welcome Aboard!
Silvertip
Re: drain holes
Looking from the inside out -- if you can see daylight, you better plug it.
dkorzun21
Re: drain holes
Go all the way to the back of the boat on the bottom closes to the ground will be a hole plug it. Make sure you dont forget or it will full up with water could sink or mess up your engine. When your done take it out should drain gallon or so of water.
