I just recently purchased a '75 tri-hull open bow sport boat with a two cycle mercury 850 outboard motor from the mid 70s as well. When it runs it runs great but getting it started has become a painstaking affair. I have been using a blast of starting fluid/ether which definitely helps but after reading through a bunch of these forums understand that band-aid fix will cause more trouble in the long run. I am going to try the spray bottle with the 50:1 fuel/oil mix in place of the starting fluid this weekend but I was curious what else could I have looked at or maybe do myself? Is there anything that can be done that will eliminate the need to spray to start?
I was also wondering if anyone had any suggestions that would explain the reverse ceasing to work. If I put the throttle into reverse the engine rockets into really high revs but doesn't budge. This has made trips to the marina on a busy day extremely nerve racking!
