Hi, I have a 1997 200HP Johnson. It currently bogs down under load and dies. It will work correctly for brief periods of time and it doesn't happen at low RPM's with no load so I've never been able to replicate any symptoms in the driveway.
Due to previous problems (seemed to be fuel starved at WOT, but ran fine if the primer was pumped), I have replaced all of the fuel hoses, filters, fittings, primer, the VRO and had the carbs cleaned by a local shop. The new VRO and/or fuel fittings seem to have cured the original problem but now it dies under load. After installing the new VRO and hoses, I put it back in the water and it ran great for about 5 miles. I turned around and headed home and it started with the new symptoms.
The gas had been in there over the winter so I drained it all and refilled with fresh fuel.
Any suggestions on where to start? I already paid the shop $400 to clean the carbs, but that was before this problem cropped up. I have drained all of the fuel from the tank, put in a new water separator, a new inline filter and replaced the plugs. The plugs the dealer put in were Champions, but gapped around 0.020 if that. It really looked like they were just fresh out of the box. All six plugs were wet with some carbon buildup (looked like all had been firing at some point).
I will be checking the compression and spark in the driveway, but I have no way to replicate a real load unless I put it back in the water.
Any directions for additional diagnostics will be greatly appreciated.
Thanks,
John
Thanks,
John
