Re: Yamaha 250 OX66 Help
Service your O2 sensor every 100 hours.
www.boatsetup.com/O2sensor.pdf
Also, you can make sure your oil rod linkage is correctly adjusted.
For the oil linkage rod adjustment, disconnect the butterfly linkage on the starboard side of the motor, just the bottom set. This will allow the oil linkage rod on the port side to seat freely. Use a feeler gauge on the oil pump, I have read .020 and .005. I used .005. on the oil pump, measure between the oil lever and stop. You may have to cut 5 threads off of the linkage rod to screw the plastic collar down enough.
There is also an o-ring behind the oil pump that can leak, but do the O2 sensor and linkage adjustment first.
