clemsonfor
- Sep 19, 2005
- 1,011
im thinking of putting a fuel water separator (the spin on type) between the tank and motor, where else i guess, but started to think will it put to much resistance in the fuel system? Is my motor big enough to pull this fuel through this system and not starve the carbs?
i have a 1981 (2cyl) johnson 60Hp
Thanks nate
The reason i am putting this in is that when i got the boat the guy had a 12 gallon tank on the deck, but there is a belly tank in the boat. He said there was not a problem it was just big and the motor does not use that much fuel, which it dosent. My thoughts were he had probles with water or trash. Leaks are also a possibility i guess , although i was able to siphen some old gas out to drain the tank with the line, the hole if there is one could be above this point? The other problem is that when he redid the floor he sealed it up in there and with the new console there is not gauge, this is not a problem i know how much fuel i use and can just keep it filled, and i also though about putting a 3 gal portable tank in the back just incase.
I just want to get the 12 gallon tank off my deck and free up floor space in this 16 ft center console!
-nate
Thanks nate
-nate
