I have a 1977 Evinrude 115 hp outboard motor. It came with an older boat I just purchased. I had the boat out on the lake and it seemed to run fine with a few what I thought were fuel supply issues. In taking the boat and motor in for a ?summer? tune up and to have a new water pump put it, I was told I had damage to one of the cylinder?s rings. The ring apparently got brittle and cracked and then damaged the spark plug. I was told models of this motor during this period had ?high? placed rings for better performance. The caveat was they had to run on gas with a 96 or thereabouts octane rating. Apparently the US government outlawed 96 octane gas in the 80?s and this results in increased heating to the cylinders/pistons/rings with lower octane gas causing heat related damage to the rings and my problem. Is this a correct understanding? If so, can new pistons/rings still be purchased to repair this problem.
