Re: 19 pitch prop 24mph what do i need to increase?
In all honest, I am no expert in this, but from reading and studying manual, formums, etc, I'll try to give my take.
There is a recommended rpm range of the motor by the manufacturer at WOT. From my understanding, if you are unable to reach that RPM at WOT, then you are placing a much larger load on the motor. I can't say what that means for the motor exactly, and I'm sure some of the experts on the forum could tell you more.
Also, there is a relation to speed and rpm, and there are calculators that will give the top end speed based upon the proper rpm range, gear ratio, prop pitch, and estimated slip. But in all honesty, speed is not the main concern and it's only a byproduct of the motor. If you are not getting the speed you are looking for (which doesn't seem to be your concern), and the motor is propped correctly, then you/anyone should get a larger motor.
The goal is always to prop the motor properly to get the best performance out of the motor for the particular load and usage. If the motor is working as it is supposed to, but is not getting to the proper rpm, then it is overloading the motor (to my understanding), which probably means you are not propped correctly. Likely, you can possibly throw a rod or something even worse. If you are going beyond the rpm range, then you have the possibility of overheating the motor and locking up the motor to say the least.
Please, anyone, correct me if I am wrong on any of this.
