Broderbrem
- Jun 14, 2009
- 3
Hi. I hope some of you can help me find out whats the problem with my starter (In Sweden where I live, Force engines are hard to find = no one to ask).
The starter spins but bendix gear does not engage the flywheel.
I have changed battery and polished all connections. I have lubricated the bendix spiral shaft (its now very easy to raise by hand).
I have measured the battery (12.9 V).
Then I measured the solenoid without the starter engaged = 12.8 V
With the starter engaged = 0 V
The starter gets 9,1 V when I measure it while its engaged.
If I engage the starter so it spins and take a screwdriver and gently push under the rotating bendix so it jumps up to the flywheel it almost stops and you can hear that the starter struggles to rotate. But it doesnt have the power to rotate the flywheel.
Someone?
(I hope you understand my not so good english
Someone?
