DukesFin
- Oct 12, 2005
- 500
I ground down some nicks, scratches and chips on the boat today and got a thin coat of resin over the exposed glass...
Then I started looking the whole boat hull over and decided that I'd paint the whole hull. I like Interlux Brightsides medium blue color for sides and white for the bottom. I'll be priming it with the recommended primer from Interlux.
My question is, can I sand down the existing gel coat and apply the Interlux primer over it or do I need to either get the whole hull down to glass (not likely), or can I only use gelcoat over gelcoat?
If I can put it over gelcoat, I'm assuming that I clean and sand the exisiting gel coat to give the primer something to hold on to, but what grit would be appropriate?
Thanks!
I'll post the "project" as I move forward!!!
Oh, it's a 20' Cabo 204 Centercon (center console) if that matters at all!
Thanks!
