timmeraw
- Jun 10, 2008
- 258
Hello all,
I recently was very fortunate in picking up a 1955 (Thompson maybe..the jury is still out) molded mahogany plywood outboard boat that had sat in a barn for 40+ years. It originally had a 25hp Johnson Seahorse that was in the barn but rusting away so bad I left it and the pre-50's trailer it was sitting on there. As I work to restore it I was looking for a similar engine and today I found/bought the EXACT same outboard(a '54 Johnson 25hp) that is is good shape cosmetically but has not been run in a great many years.
It does turn over and has good compression(maybe too good as it is a lot harder to pull than my fathers 80's Johnson 25 we used when I was growing up. But in any case....my question is...before I even attempt to get some new gas in the old pressurized tank I got with it...what is the procedure that I should do to prepare to attempt the first start? Such as check/replace the plugs ...check spark, go right to cleaning the carb, replacing the coils/points etc. Get a shop manual(which is my next step on the internet) etc. Or should I just put some new gas in and give it a shot?
Of course if it is not pumping water I will shut it off and replace the impellar(gonna do that anyways).
Any tips/hints will be greatly appreciated. I am so psyched that I found the same original motor...in the same day I went back to the seller or my boat and rooting
around in the barn found some various original parts(stern light, deck spotlight, a missing piece of stainless trim for the transom and the big find....the center deck piece that brings it all together.
Thanks for your help with this old motor.
Sincerely,
Timmy
Sincerely,
Timmy
