69' 55hp Evinrude Runs great till warm or loaded then Dies
Mike_krab14
Hello I have a 69' 55hp evinrude... When im using the boat....it runs great for a little while then It starts to miss like crazy and eventually quits...if you let it cool for 1/2 hour or so it runs again great and repeats itself and then starts missing and then dies.. I change the powerpack... i changed the coil.... i check wiring.... battery is right up,...could this be a faulty condensor because ive clean the points as well......sometimes i get longer use out of it then others.... but i find the more load the faster it quits.... like when i have a skier or even just 4 people onboard... And im pretty sure i have proper fuel supply as well or it would run this way hot or cold......
Thanks...
Mike
Rodneys
Re: 69' 55hp Evinrude Runs great till warm or loaded then Dies
I have got 2 of these junk ( temper mental ) motors. If it is over heating, maybe it's the thermastat.
Mike_krab14
Well Ill give it a try... if not back to the drawing board
