It is easier to just pull the port side cover and use a Dremel tool cutter or a chisel to split the aluminum clevis piece. Then remove the screw holding the clevis to the shaft and you are done.
A new clevis and screw and lockwasher assembled using marine grease will be fine for a long time.
