1994 Johnson 175hp Ocean Runner V6
Recently took apart each carb and replaced gaskets with new kits. Re-installed the carbs and started the engine. Fired right up, but immediately running at high rpm + 2000. Let it run for 30sec and RPM increased to +3000, the engine was definitely racing, meanwhile throttle control was in neutral. Could not get it to idle down. Any suggestions? Pretty sure my carb rebuild is to blame but not sure where to check first.
Thanks
Thanks
