Hi everyone
Frist time on, just found the site,from Alberta.
Anyways I own a 1984 Baylinner
Just replaced the button so I can release the lock on the 270 leg when rasing it. Sould be locked for reverse.
Question is.... Should the leg be locked when driving forward.
I would thing not ,so if it hits a rock the leg could lift and not break off.
If it should not lock how do you set it up .
Second question.
Q125A with a solex carb
When shifting from neutral to forward engine runs fine.
Then push the lever forward alittle more into next postion
(you can fell alittle bump in the linkage ) then engine wants to stall.
When looking down the carb the butterfly just opens.
Primer pump on carb works good.
What I do so it will not stall is, pump the lever back and forth between 1 and 2nd gear as i call it. and engine will speed up and not stall .how do i fix it?
Third Question
The lake water pump seems tobe leaking . Have not taken it apart yet.
Is that shaft being driven having a rear seal or oring as it seems like the leek is on the back side and not the front plate.
Thanks for any relpies
Second question.
Third Question
