1998 60hp Johnson Replacement Fuel Pump
hocman
VRO2 unit has gone bad and i want to replace it with a standard fuel pump and run premix. Can someone point me towards to a correct standard mechanical pump for this motor. Does Sierra make one that will fit?
Thanks
tashasdaddy
Re: 1998 60hp Johnson Replacement Fuel Pump
sierra does not have one that large.
Vro Replacement Fuel Pump Kit "no Oil"
(for Using Oil/gas Pre-mix In Fuel Tank)
#5007422 it is in the $300 range.
$100 range
Part Number: 0385784
Description: FUEL PUMP AY
Pack Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0395712,0398385,0433390,0438559
