bang in gear
jebby
i have a johnson seahorse 10hp from i believe 1954 (could be 53 or 55) that bangs every few min in gear. was told the clutch dog is worn down. is this something i can just flip around into reverse or do i need a new one? also how much work would this be to do?
tashasdaddy
Re: bang in gear
you may be able to flip it. but it is a temporary fix, as the bad forward gear will wear out the other side.
F_R
Re: bang in gear
Clutch dog, Forward gear, shift linkage--all are related. Fix one thing without fixing the others and plan on doing it over again later on. Waste of time and $money.
asdasc
Re: bang in gear
I was just looking at one I have apart from an 18hp, and the clutch dog is REALLY worn and rounded, while the gears look pretty good. Are the clutch dogs designed to wear to protect the more expensive gears?
MushCreek
Re: bang in gear
When I was a kid we used to reverse tired clutch dogs all the time. Who needs reverse anyway?
F_R
Re: bang in gear
No, they are not. Sometimes it just turns out that way, sometimes it doesn't. Neverthess, a new dog against a worn gear results in a very small point of contact at the points of the dog/bottom of the gear cavity. They'll wear off quickly.
jebby
Re: bang in gear
thanks for the info thinking il give it a try because i have nothing to lose. even if it gets just a bit more life i suppose its worth it
