Coach Doss
 - Jun 28, 2009
 - 2
Hello All! Thanks for the help in advance!
I have recently become the owner of a 77 merc 1150. I need some help getting the thing running. I can get it to crank and run with water muffs on and I get it to the water and it wont start. The only way I can get it to cold start is by adding some gas/oil mix into the cylinder through the spark plug hole. After I get it started it runs fine. After it runs a while I can cut it off and it will start up like a new one.
My problem comes when it sits for about 10 mins. then the only way I can get it started is to add the fuel/oil through the plug holes.
Can someone give me some ideas on what the problem is and how to correct the situation. I am new to boating and would be glad to take any advice.
Thanks!
Coach Doss
Thanks!
Coach Doss
