Mercruiser 454 Overheating after 1 -2 hours~
Status
Not open for further replies.
I have a 1990 Baja twin 454's. 1 motor is overheating. It has a new seapump, water pump, thermostat & temp gage.
The motor runs about 180 degrees for about an hour and half. When speed up, the temp climbs. The motor kind of "bogs down" then temp gage shoots to 220 degrees. This past weekend we were able to run almost 2 hours until we had a problem.
The other motor runs just fine!
Any suggestions as to what might be going on with this motor....I am stumped!
Thanks for all suggestions!
maxxman04
Re: Mercruiser 454 Overheating after 1 -2 hours~
bad thermostat, water pump. are engines injected or carbed?
I've replaced the thermostat two times, but it continues to overheat. It is carb.
maxxman04
check impeller in that motors outdrive. also, you may want to pull the plugs and note each ones condition, check to see if they all look the same. there is a slight chance you may have a head gasket problem.
flargin
Pull off the water line connecting the in-side to the oil/PS cooler. check for pieces of old impeller in the cooler, jammed there.
impeller parts do not make it out...
gaiter
Curious as to the outcome of this problem, my boat did the same thing to me today - ran fine until I cornered it for a bit, then sounded the alarm and spiked up to 220 degrees. Once I came down off plane, the temp went almost immediately back to normal around 170, but the engine would not run for about 10 minutes or so. Then started up and putted home with no issues. Any comments are appreciated. BTW motor is a 99 7.4L MPI.
Status
