boatvinnie
- May 13, 2009
- 3
Hi,
I have a aluminum pontoon boat with an old 20hp motor.
The motor is not able to charge a battery, however I was hoping to install a stereo and two cigarette lighter adapters to a single 40ah marine battery. The boat is tied up to my house so I will just recharge the battery at the end of the day (and maybe add a solar battery charger during the day as a bit of a gimmick).
The stereo I am planning to use is a homebuilt combination of a d-class amp (very low power consumption) powering two small bookshelf speakers. The amp currently runs off a 12v 1.2amp power supply. I was hoping to wire this up straight to the battery, with only a fuse between the amp and the positive terminal.
The two cigarette lighter adapters would be used for a combination running light (white/red/green - about 10w) and a general purpose (GPS/charging ipod etc). The lights would be used only rarely, but it is nice to have the ability. The gps/charger would also only be used occasionally.
I was also going to wire these up straight to the battery with fuse in between.
Questions:
-Does this sound like it would work? Is there an easier way?
Would it be easier to run all three off a single fuse and a single connection to the battery?
-What size fuses are recommended for each of the three? I realize a 1.2 amp stereo would suggest a 1.2amp fuse, but do you normally add a little to make sure it doesn't blow all the time?
-I am assuming I would need to ground this, would the easiest way be by simply running a wire to the aluminium pontoons/railings?
Any help most appreciated.
-Vincent
Questions:
-Vincent
