It starts easily and runs fine at idle. At half throttle it starts to hesitate and surge. At full throttle it will only run about 4000rpm. I have changed all six plugs and have spark, rebuilt the carbs, replaced the fuel fittings, checked all fuel lines for blockage. The compression is 90psi or more. Fuel pump is clean and looks good but will rebuild it when the parts arrive. I suspect it is a stator problem but don't know how to check it. Any ideas?
