Mark42
- Oct 8, 2003
- 9,334
The 1985 Force 85hp had no disconnect on the fuel line. The fuel line passes through a plastic fitting that also holds the shift and throttle cables, and is clamped to the fuel filter.
I recently added a permanent fuel tank and new Acol 5/16" marine fuel lines. Turns out the fuel line is way too thick to pass through the hole originally intended for the fuel line.
So I decided to add a quick disconnect like my Evinrude has. All that is needed is:
A standard brass male fitting:
A female connector:
A 5/16" 1/4 hose barb:
and a 1/4" NPT 90 elbow:
The plan is to drill a 1/2" hole in the lower motor cowl and insert the male fuel connector. Thread on the 90 elbow from the inside. As they tighten, the cowl is compressed between the two (a few stainless 1/2" washers will take up any slack to make it tight). The the hose barb screws into the elbow. A length of 5/16" fuel hose connects the motor to the hose barb, and the female connector makes the connection to the fuel line.
If it ever stops raining, I'll take some pictures of the real thing.
A female connector:
