fishindad71
- Jul 1, 2009
- 4
This is a great forum! I?ve got an older 7.5HP 1969 Sears outboard made by McCullough. The model number is 574-60210. Do you know the proper oil / gas ratio for this? I made up some 32:1 fuel but it seems to produce more smoke than I expected.
Also, for this same motor, I?m replacing the impeller as a standard precaution. How much water should be coming out of the motor via the impeller and where should it be exiting? I see the ?usual? pair of holes on the back of the leg, but I also see an outlet on the side of the leg. When I removed the lower unit, I noticed an aluminum tube running from the water pump to this outlet on the side of the leg. I?ve never seen any water coming from that outlet when the motor was running but I was able to see sporadic spitting of water out the ?normal? two holes on the back of the leg.
Thanks,
Kenny
Thanks,
Kenny
