1991 50hP Johnson won't idle
IRONRANGER
91 50hp johnson won't idle, (rebuilt carbs) I can get it to start when throttled up but will die after a few seconds, but if I hit the choke it run a little longer, won't run without throttled up?
Big Bubba
Re: 1991 50hP Johnson won't idle
Clean, clean, clean, clean the carbs really good and make sure every orifice jet is completely clear. Reason I say this is you might not have gotten it the first time cleaned as good as you thought you did. Also check the fuel lines for fuel leaks. Let us know what you find out. Take care, Bob
IRONRANGER
the carbs where spotless I dipped them and blew out everythig great ,used little wires and flashlites, absolutly spotless.
tx1961whaler
You've got good compression (other thread), and good spark (assuming it runs fine at high speed...), than all that is left is fuel delivery. Check for air leaks in the lines, make sure the spark plugs are clean, etc. When the carb was rebuilt, was the welch plug (#5) removed and all of the tiny idle passages cleaned out?
The (#7) nozzle gasket needs to be in real good shape also
convert
tashasdaddy
do a linc n sinc. should solve your problem, you are idling too slow.
Silvertip
Some of those carbs had idle mixture screws. If you removed them, have you readjusted them properly -- in the water, not on muffs.
IRONRANGER
I have the slow speed idle adjusted out 1 1/2 turns on both carbs, what does the linc n sinc consist of?
IRONRANGER
O-ya, It wont idle even with some throttle , unless you hit the choke every few seconds. it wont even start without some throttle.
Ware5150
I have had a lot of idle problems with my 85' 115. I corrected some issues by adding a clear inline fuel filter from Walmart. I then could see that is was running out of fuel and not staying full after pumping. Using an air compressor I found a small leak near the bulb. Fixed the leak and Fuel delivery is not an issue anymore.
Hope this helps.
