Re: Newb question-tying up in slip
I tie up anywhere from 150 to 200 boats a season
6 Lines
4 15'
2 20' to 25'
2 Bow (15')
2 Stern (15')
2 Spring (20') if you have mid ship cleats (25') if you don't.
Start with the bow lines. Get yourself close to the dock and temp tie off in a criss cross with 2 15's,this is to keep the boat floating out of the slip
Next the spring lines. Start on port.
If you have mid ship cleats loop the line under and back over the cleat, walk the line to the bow and and half wrap it around the piling. Now with the line in your right hand push back towards the dock, let the line run through your hand and grab the other side of the line (from cleat that runs to piling) when you are about 2' from dock. Pull on BOTH sides of the line to get away from the dock, now, wrap the line once around the piling, make a half hitch, wrap again as many times as you can to leave yourself enough line to do 3 more half hitches.
Repeat this for the Starboard side.
If you don't have mid ship cleats, then use 25' to the stern cleats, but do the same process as above.
Now for your bow lines.
Left cleat, left piling.
Loop 15' under over on cleat, half wrap piling, push to starboard, stop boat 1' from piling, pull back and tie off like spring.
Repeat for starboard.
Bow, adjust temp tie off, pull boat back until spring is taught, then let out and tie off.
Done properly should take no more then 20 to 30 minutes.
Or just give a dock hand 20 bucks and he will do it for you.
