i picked up this old glastron. i think it's a 57, though it could be up to a 60. it came with the original 60 hp mccolluch engine.
i'll post pictures, but what i've done so far is this:
1. i turned the key, i heard fizzing, so i stopped. the starter burned up... i mean waaaayyy up. smoke billowed.
i went all over the place looking for a starter. noone had one (still awaiting word on some) so i took it to a place to rewind it. expensive, but worth it.
2. the guy who had it before me said it would start, but not stay on. so i thought it was one of three things,
fuel pump,
fuel filter,
something horribly wrong, like compression, or something in the carb.
i took off the fuel pump. the filter was full. too full, and the diaphram was ripped all the way down.
i searched for a fuel pump diaphram. i couldn't find one anywhere.
this particular engine is so obsolete i get laughed at when i'm looking for parts.
so i put it on hold as i search for those particular items.
the main point to me getting a boat in the first place, was to use it. restoration is secondary. so i looked online until i found a (what was advertised as)1972 65 hp merc.
turns out it was a 1966. no big deal, except the manual he had didn't match it.
it was torn apart. however, the starter works, as does the fuel pump. the problem i've found with this motor is compression. a seal lets in air after the motor is running for a couple minutes. then it quits. what do i do? do i put a new gasket in it? or is there an exterior type goo that hardens into an external gasket? i've heard of it, but i dont' have any idea if this is the proper application for it...
my gas tank has chunks of black crap in it. and it leaks, so i'm focusing on that right now.
also, i've put that motor in the boat. it'll be replaced with the original when it's back in running condition.
the trailer is rusting. i coated it in rust converter. but it turned out it was too old, and didn't really work. this is no problem, i've been putting a little elbow grease into it with a brush when i get stumped or frustrated with the motor.
the steering wheel is in bad shape. any suggestions? the rubber that was on there is almost all gone...
fuel pump,
fuel filter,
