Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
1994 5.7 Mercruiser with an Alpha. In neutral and in reverse, RPMs will max at 4400, while in forward gear it only goes to 2000 RPMs. Out of the water it will go up to 4400 RPMs in all three (neutral, reverse and forward).
4000 rpm on land is very good,trouble is you wiped out the impeller in the lower unit doing it .Land rpm means squat.Was it serviced with a full tune-up?
prop in good condition?,any bottom growth?
It has not have had a tune up. The distributor cap had condensation I whipped it dried, no misfire. Prop is in good/great condition and not spun. No bottom growth. Its just weird why in the water it gives me full RPMs in neutral and reverse. In forward at full power its just gives me 2000 RPMs max and will not pass 10 MPH.
It has not have had a tune up. The distributor cap had condensation I whipped it dried, no misfire. Prop is in good/great condition and not spun. No bottom growth. Its just weird why in the water it gives me full RPMs in neutral and reverse. In forward at full power its just gives me 2000 RPMs max and will not pass 10 MPH. Could it be that I may have move the linkage cable as I used some tie-straps to hold some wires onto the cable?
