Re: Overheating
An update on the saga.
I flushed it this morning and took it out for a lap. The water coming out of the pee hole after running is hot to the touch but the overheat alarm never went off. It seems like less water is coming out when at higher speeds. When we got back in, you could not hold your hand under the water because it was too hot, but you could put your hand on the engine block without burning yourself.
The other thing is that I could not find the tstat on the boat. The water discharge comes out of the top of the engine. Any clues? SN for the engine is 0G267379 - 1995 40 HP Merc with oil injection.
