Re: Throttle cable
The fast idle lever and the throttle lever serve two very different functions. The fast idle lever is just that. It allows you to raise the engine speed slightly during warmup. It is not supposed to open the throttle fully. If you've been messing with the throttle cable adjustment trunion you probably have it screwed up. To properly adjust it, disconnect the cable from the engine. Place the throttle/shift lever in neutral and make sure the fast idle lever is fully down. Hold the throttle linkage firmly against the stop on the engine. Now bring the end of the cable up to the attachment point on the the throttle linkage. Do not move the linkage. If the throttle cable does not line up exactly with the attachment point on the linkage, adjust the trunion so it does. Then connect the cable. Thats the only adjustment you have for the throttle cable. Now push the throttle lever all the way forward. The butterflies in the carb should be perfectly horizontal in the carb throat. If not, you now need to do a link&sync for which you will need a service manual specific to your engine. Throttle and ignition timing are synchronized which is what that process does. It is far to long and detailed to outline here -- hence the need for a service manual.
